The MAX31850/MAX31851, cold-junction-compensated, 1-Wire thermocouple-to-digital converters were introduced today. The devices achieve ±2.0°C accuracy (not including sensor nonlinearity) while integrating all of the functions required for a complete (thermocouple-to-digital solution). Additionally, the MAX31850/MAX31851’s 1-Wire interface allows multiple sensor locations to communicate and draw power over a single data line, greatly simplifying wiring requirements. Designers can use the MAX31850 or MAX31851 instead of multiple discrete components for accurate temperature measurement in medical, industrial, and solar applications.
Because thermocouple output voltages are small and cold-junction compensation is needed to achieve accurate results, the digitization of thermocouple signals can be a challenge. The MAX31850/MAX31851 are the industry’s first solution to integrate a discrete analog-to-digital converter (ADC), a highly accurate reference, a temperature sensor for cold-junction compensation, and a 1-Wire bus interface into a single chip. The versatile converters operate with several types of thermocouples, speeding system design, lowering system cost, and reducing the bill of materials (BOM). The MAX31850/MAX31851 also identify open or shorted thermocouples that could result in erroneous temperature readings or system faults. A microcontroller can read the fault status at any time to help ensure uptime and prevent costly repairs.
Key Advantages
- High integration and accuracy: converters achieve ±2.0°C accuracy while combining multiple discrete component functions into a single chip.
- Simplified designs: the devices’ 1-Wire interface allows for a large number of devices on the same communication bus. Their four dedicated address pins uniquely identify up to 16 sensor locations.
- Versatility: the MAX31850 is available for K, J, N, T, and E thermocouple types and the MAX31851 is available for R and S thermocouple types.
Availability, and Temperature
- Available in a 10-pin, exposed-pad TDFN package (3mm x 4mm x 0.75mm).
- Specified over the -40°C to +125°C temperature range.
Maxim Integrated
www.maximintegrated.com
The post 1-Wire Thermocouple-to-Digital Converters appeared first on Analog IC Tips.
Filed Under: Analog IC Tips
