Larson Electronics, a leading industrial lighting company, releases a new 25 watt rechargeable high output LED spotlight that includes an AC and DC charging adapter providing operators in-home and on- the-go charging capabilities.
The RL-85-LED-CPR rechargeable handheld LED spotlight from Larson Electronics is a lightweight, ultra rugged, ergonomic handheld spotlight equipped with a 7.4 volt lithium ion battery pack. The battery pack for this spotlight provides a two and a half hour operation time and may be recharged in three hours from a completely depleted state. This high output LED spotlight is constructed with a single 25 watt Cree LED and features an advanced reflector and lens configuration to generate a 2,000 lumen light output. Drawing only 25 watts, this light produces a beam capable of reaching distances over 1,000 feet. The Cree LED unit used in this light generates eighty lumens per watt with 70% lumen retention at 50,000 hours, giving this lamp better efficiency and a longer operational life than traditional spotlights.
This IP65 rated waterproof LED spotlight features an ultra-durable ABS shockproof polymer body, aluminum alloy light head housing, and an impact resistant polycarbonate lens. The unique shape and shallow contour of the reflector is paired with a convex lens and inset lens positioned to efficiently capture and project a focused beam of light while reducing light spillage. The pistol grip style, nylon handle has a no-slip textured surface to improve grip and has a conveniently placed push button so that the user can easily access the power switch with the fore finger for quick on/off operation.
Larson Electronics will be attending the 2016 OTC show in Houston, Texas from May 2nd to May 5th. Visit them at booth 6716 to inquire about their lighting solutions for many industrial applications.
Larson Electronics
Larsonelectronics.com
Filed Under: Power Electronic Tips
