Larson Electronics, a leader in the industrial and commercial lighting industry, has announced today the release of a 33 watt four foot Class 1 Division 2 LED strip light equipped with a twenty foot cord terminated with an optional explosion proof cord cap.
The HAL-48-33W-LED-1227-20C hazardous location LED strip light from Larson Electronics is designed to provide a high output and ruggedly durable lighting solution for applications where Class 1 Division 2 compliance is required. This powerful four foot LED strip light produces 2,416 lumens, operates from 120 to 277 volts AC, and is suitable for a variety of applications. This strip light is constructed of powder coated extruded aluminum for excellent strength and durability and carries an IP54 rating, providing limited ingress protection against dust, and basic protection against splashing water. This strip light is weather resistant, suitable for indoor and outdoor applications, and ideal for areas where wetness or dusty conditions are commonly encountered.
Mounting for this LED strip light is provided by two adjustable end brackets that allow the operators to mount the light to flat surfaces and then adjust the light 170° vertically. Measuring almost forty-eight inches in length, this hazardous location strip light is ideal for areas where space is limited, such as illuminating control panels and under cabinets. This hazardous location LED strip light is equipped with twenty feet of 16/3 chemical and abrasion resistant SOOW cord that is fitted with an optional explosion proof cord cap for easy connection to corresponding explosion proof outlets.
Larson Electronics
Larsonelectronics.com
Filed Under: Lights • signal lamps • indicators, Flanges • supports • mounts • brackets, Power Electronic Tips
