The gigabit managed Ethernet switch line (LMX-0800G series) handles applications in harsh or outdoor environments. These applications include: power/utility, solar grids, windmills, mining infrastructures, and factory/process control automation.
The LMX-0800G series is an 8-port industrial gigabit managed Ethernet switch with a 12 to 48 Vdc power input range. Each unit is designed with eight 10/100/1000Tx RJ45 ports. A 16-Gb backplane speed supports Jumbo Frame and wide bandwidth for large Ethernet data packet transmission for edge level connectivity solutions.
The product series provides high EFT, surge (2,000 Vdc) and ESD (6,000 Vdc) protection. It is also built with a dual power input design with reverse polarity protection, and has a built-in relay warning function to alert maintainers when power failures occur. This makes it ideal for applications demanding a high reliability and distance extension
This product series is pre-loaded with “Layer 2” network management software that supports an ease of use Web Console or Telnet through the serial console by CLI configuration. These managed switches provide the ring network redundancy function with STP/RSTP/MSTP and the ITU-T G.8032 (ERPS – Ethernet Ring Protection Switch) protocol which supports a less-than-50-msec network recovery time, eliminating the compatibility issue for any existing network concerns. In addition, the built-in SNMP, VLAN, IGMP, QoS features support network planners to increase data transmission performance within the network. The external USB 2.0 port lets users export and save all the configuration settings. Lastly, the flexible “custom label” feature allows networking planners to name each connection port. By naming each port, the networking planners can manage remote field devices.
The LMX-0800G series units are IP30 rated, compact, fanless, DIN-Rail and wall mountable. Each series is built to withstand industrial networking hazards like shock, drop, vibration, electromagnetic interference (EMI) and extreme temperatures. There are two operating temperature version models for either standard temperature
(−10 to 70° C) or extended temperature (−40 to 75° C). The models have the dimensions of 54 × 99 × 142 and a unit weight of 2.1 lb.
Antaira Technologies
www.antaira.com
Filed Under: CONNECTIVITY • fieldbuses • networks, ENGINEERING SOFTWARE
