A full line of transfer tubes for building vacuum conveyor systems that are powered by compressed air to feed hoppers, evacuate dust, and remove trim waste is available from Anver Corporation.
Anver TT Series Transfer Tubes are powered by compressed air and employ the Venturi principle to instantly create vacuum, controlled by regulating the input pressure, for conveying a wide range of materials at different speeds. Featuring smooth bores and no moving parts, materials actually pass through these transfer tubes which are totally maintenance-free and explosion-proof.
Suitable for a wide variety of applications, Anver TT Series Transfer Tubes come in bore sizes from 0.375” to 1.0” I.D., with infinitely adjustable air flows from 15 to 95 SCFM, respectively. Machined from aluminum and ano-dized, these transfer tubes use no gaskets or O-rings, and are available with optional mounting clips. One air source can operate several tubes.
Anver Corporation
www.anver.com
