Microjammer variable-speed, brushless DC blowers have been newly engineered for increased life, reduced vibration, and improved performance. These low-voltage, 12/24 Vdc blowers are used in a wide range of medical and industrial applications, including respiratory equipment, cooling systems, and air sampling equipment.
Their redesigned bearing system contributes to longer life, and a rear-balancing disk significantly reduces vibration of the blower’s rotating fan system. Both features come standard in the 5.1 in. (130 mm) blower and can be specified for blowers in sizes 3.0 in. (76 mm), 3.3 in. (84 mm), and 4.5 in. (114mm).
Microjammer 3.0, 3.3, and 4.5 in. blowers further integrate a next-generation 0.5 wave (uni-polar) electronic controller into the motor to enable compact and improved 2-wire operation. Optional 8-wire configuration for connection to external, full wave (bi-polar) electronic controllers is also available.
Additional options include an FPS (frequency pulse signal) for speed, tach output, and a separate V+ signal wire for input power to Hall sensors to extend low-speed operat Microjammer brushless DC blowers have output pressures to 51 in. H20 and flows to 26 CFM, depending on the model. All can be customized to satisfy particular application requirements.
About Ametek Technical and Industrial Products
AMETEK Technical and Industrial Products (TIP) is recognized as a leader in the design and manufacturing of blower, motor, and pump products for a wide variety of applications. It is a leading global supplier of Brush and Brushless DC Motors, Pumps, Controllers, Brushless Blower Systems, and Regenerative Blowers. Its design expertise, exceptional customer service, and state-of-the-art ISO 9001/9002 manufacturing enable the company to provide high quality custom design products in cost effective packages.
For more information, visit: www.ametektip.com.
AMETEK Technical & Industrial Products
627 Lake Street, Kent, OH 44240
Tel: 330-673-3452
Fax: 330-677-3306
:: Design World ::
Filed Under: Appliance engineering + home automation, Fans, Medical-device manufacture, MECHANICAL POWER TRANSMISSION
