Optima M-Series Cabinet Enclosures
Tucker, GA – Optima EPS, an Elma Company offers M-Series cabinet enclosures that have been fully tested to MIL-STD-810-F and MIL-STD-901D for shock and vibration.
Optima’s M series cabinet enclosure is designed for rugged applications for Mil/Aero, Seismic Zone 4, or Mobile applications. The cabinet has a unique modular construction designed to exceed military standards and can adapt to the equipment-mounting and protection needs of virtually any electronic system. The enclosure employs thicker gauge aluminum, reinforced corner members, cross-bracing, spot welding, and a reinforced base to withstand extreme environments. Testing for the M-series included a vertical axis, longitudinal axis, and transverse axis tests for shock and vibration for MIL-STD-810F. The 901D barge test included Grade B Class II testing.
The M-series can accommodate customer specific requirements for EMC shielding, shock and vibration, mobility, thermal management, power distribution/conditioning and I/O cabling per the application MIL-STDs.
Optima, An Elma Company
www.optimaeps.com
Speak Your Mind
