Industrial Encoder Corp. now offers its biggest bore hollow-shaft encoder yet.
The IH150 series encoder is for the most demanding of applications …
… and is available with a whopping four-in. hollow bore.
Industrial Encoder Corp. has one of the widest ranges of hollow bore encoders in the industry — with bores from 0.25 to 4 in. and everything in between.
If it is not in standard product offerings, the manufacturer can also tailor custom designs to even demanding requirements.
For more information about this durable encoder, call Industrial Encoder Corp. at (888) 277-6205 or email [email protected].
IH 150 incremental hollow-shaft encoder general specifications
Heavy-duty construction • Shaft mounted • Range of shaft bores — 2.5 to 4 in. (65 to 100 mm) • 5,000 PPR maximum • 4.75 to 30 V • RS 422 compatible • 300-kHz maximum frequency
IH 150 incremental hollow-shaft encoder electrical specifications
Supply voltage — 4.75 to 30 Vdc • Current consumption — 40 mA maximum
Output circuit — Push-Pull, RS 422A • Impulse frequency — 300 kHz (max)
Signal level (high) — Vcc – 0.7 V • Signal level (low) — 0.3 V maximum
Short circuit protection — 100%
IH 150 incremental hollow-shaft encoder mechanical specifications
Cover — Aluminum • Body — aluminum • Shaft — stainless steel
Speed — 4,000 rpm maximum • Torque — greater than 0.02 Nm
Loading — Axial 80 N, Radial 60 N • Environmental protection to IP 65
Operating temperature of -200 to +700 C (-40 to +1,580° F) — or to +1,000° C (+2,120° F) optional • Weight — 720 g (1.584 1b)
