The short answer is No. Contributing Editor Josh Cosford explains why:
I’ve never seen copper washers used in hydraulics. Even though it’s a little bit malleable, it’s not soft enough to allow positive seal between too hard surfaces. There are some companies that make some seals that can go on a JIC so that it has a soft seal between two surfaces. If it’s a temporary thing, the chances of getting a copper washer to the exact shape and dimensions of the fittings that you’re trying to seal up again is going to be hard to come by.
Instead of going out to look for washers, you’d be better off going out look for somebody that can redo your hose or get some new fittings for you. But, I wouldn’t recommend that either. It just sounds like a disaster for leakage. The pressure is too high. If there’s any imperfections in the surfaces between the copper washer and the metal of the fitting or the tubing or whatnot, at 3,000 psi, it’ll find its way through there. The copper washer is not going to stop it.
The post Can a copper washer be used to seal a minor leak where a hard line enters the hose fitting? appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
