AutomationDirect’s NITRA line of pneumatic products now includes additional compact modular valves which provide versatility and easy assembly.
The 24VDC compact modular valves are designed for performance, flexibility and modularity combined with sturdy mechanics. Valves are available with 3-way/2-position, 5-way/2-position and 5-way/3-position configurations with single or double normally-open or normally-open/normally-closed solenoids. Valves are offered with a 3/8-in. push-to-connect tubing input and output sizes of 5/32 to 3/8-in.
Compact intermediate modules have also been added. In applications with a large number of high flow valves, an intermediate through module provides additional air inlets. To provide dual pressures in a manifold, an intermediate blind module serves as an independent supply to valves to its right while blocking the main supply from the left. For applications requiring quicker exhaust on some valves, an intermediate exhaust module provides a dedicated exhaust for valves to its right while blocking exhaust from valves to its left.
Additional modular left and right end plates are also available. NITRA compact modular valves have various mounting positions and require no additional fittings; available accessories include 25-pin female D-sub connectors, blank marking tags, pigtail cables, 35mm DIN rail mounting brackets, pneumatic release tools, and more.
AutomationDirect
www.automationdirect.com
Filed Under: Flanges • supports • mounts • brackets, Valves, Pneumatic Tips
