ADLINK Technology, Inc. announced the release of its new AMP-204C and AMP-208C digital signal processing (DSP)-based 4/8-axis advanced pulse-train motion controllers, enabling high pulse output and encoder input frequency up to 6.5 MHz and 20 MHz, respectively. Leveraging ADLINK’s Softmotion™ technology and easy-to-use utility, the AMP-204C/208C offer comprehensive and application-oriented motion functionality, reducing development time and cost up to 25% while maintaining superior throughput and accuracy. In addition, customer-reported testing shows a reduction in time required for action completion using the AMP-204C/208C as compared to other motion controllers, enabling at least 10% growth in productivity. The AMP-204C/208C feature high-speed, enhanced precision control and competitive pricing for a superior cost-performance ratio.
ADLINK’s AMP-204C/208C feature advanced synchronous motion control performance combined with point-table functionality integrating multi-dimensional interpolation; for instance, 3D linear/circular/spiral interpolation with enhanced trajectory and velocity planning is used for contouring applications in semiconductor, display, and conventional manufacturing industries. The AMP-204C/AMP-208C also support pulse-width modulation (PWM) control with three different control modes for frequency or duty cycle, benefiting laser engraving/marking/cutting applications. Moreover, hardware-based, high-speed position comparison and trigger output up to 1 MHz are applicable in AOI applications, and16 additional onboard digital input & digital output channels make the AMP-204C/208C more economical than a full D I/O card.
The AMP-204C/208C’s MotionCreatorPro 2™ Windows-based application development software package provides a Setup Wizard, shortening system installation and evaluation time and allowing full monitoring of onboard DSP and I/O consumption via a system diagnostics page. Powerful sampling page and graphic tools deliver real-time motion and I/O status and conduct further motion flow analyses.
With the DIN-825-GP4 terminal board, the AMP-204C/AMP-208C can connect to individual servos, such as the Mitsubishi J4, Yaskawa Sigma V, Panasonic MINAS A5, and Delta A2+ series, through specific cabling. The AMP-204C/AMP-208C is currently available and supports Microsoft® Windows® XP, Microsoft® Windows® 7 and Microsoft® Windows® 8.
ADLINK
www.adlinktech.com
The post ADLINK Introduces New Advanced Pulse-train Motion Controllers appeared first on Digital Signal Processing Tips.
Filed Under: Motion control • motor controls, Digital Signal Processing Tips
