Advantech’s Industrial Automation Group is pleased to announce the UNO-1252G industrial computer designed to act as a gateway for industrial applications. As small as a micro-sized PLC, the UNO-1252G is only 10cm high and DIN-rail mountable. It comes with a low power Intel® Quark processor which only uses 10 watts but powerful enough to perform data transmission and sensing in IoT gateway applications.
Gateway computers are useful because they help to connect legacy devices to the IoT without needing to replace the entire infrastructure. This small, economic UNO-1252G is ideal for this purpose since it has an array of integrated I/O ports and the ability to expand even further by using a choice of iDoor modules which is Advantech’s new modular way of adding versatile functionality to choose functions that are needed without purchasing devices that have excess cost or functions that are not needed. iDoor modules can be used to add additional cards such as Wi-Fi and GPS making the UNO-1252G ideal for use in remote locations.
The UNO-1252G includes one GB SD card to run a Yocto Project Linux distribution. The Yocto Project is an open source Linux distribution which allows the development of applications using an SDK. The UNO-1252G supports Advantech software applications such as SUSIAccess for remote control and monitoring. Also, two 10/100 LAN ports, a mPCIe card slot, five LED indicators for power, battery, SD card, COM ports and three programmable indicators to assign your own functions.
Advantech
www.advantech.com/ea
Filed Under: MOTION CONTROL, Industrial computers
