Advantech’s IIoT Automation Group is pleased to announce the launch of the PPC-3060S, a 6.5” industrial-grade panel PC for compact applications.
The PPC-3060S has a true-flat display, with no bezel, which makes it easier to read and incorporate a durable industrial ELO 5-wire resistive touch screen that works well in industrial environments and more scratch resistant. The PPC-3060S uses a die-cast aluminum alloy enclosure with IP65 certified front panel protection ensuring it can be used in tough environments without fear of knocks or water and dust ingress.
The PPC-3060S uses an Intel® Celeron Dual Core N2807 1.58GHz processor which supports turbo boost from 1.58GHz to 2.16GHz and low power TDP of 4.3W. Other features include up to 4GB DDR3L SDRAM memory, dual GbE LAN for redundancy, two serial ports, and three USB ports (two 2.0 and one 3.0) to make is easier to satisfy various simple industrial applications. With a wide range of CD power input source, the PPC-3060S will work safely between 12-24Vdc. The PPC-3060S is FCC class B certified and compliant with the EMC immunity emission standards EN55011, 61000-6-2, and 61000-6-4 for industrial environments.
With cost saving Android OS support, lower power performance CPU, Advantech’s WISE-PaaS/RMM software for centralized remote management, elegant true flat screen, and alloy enclosure, the PPC-3060S is an idea panel PC for all machine builders and industrial equipment manufacturers.
Filed Under: Displays • HMIs • operator interfaces • monitors, MOTION CONTROL
