WATSONVILLE, CA – Applied Motion Products announces the addition of a new product in the ST Stepper Drive lineup. The ST-Plus is similar in specification to the ST-S base model but adds the full functionality of Applied Motions “Q” programming language.
The ST-Plus is available in two models, the ST5-Plus and the ST10-Plus delivering 5A and 10A respectively. The ST-Plus drive measures just 3” x 3.65” x 1.75” and has 3 digital inputs, 1 digital output and an analog input accepting 0-5VDC.
The Q software allows users to create sophisticated and functional programs that Q drives can run stand-alone. The commands available in the Q software environment consist of instructions for controlling motion, inputs & outputs, drive configuration and status, as well as math operations, register manipulation and multi-tasking.
ST-Plus drives are ideally suited to applications needing full motion control capability but only require a small I/O count.
www.applied-motion.com
Filed Under: Drives (stepper) + amplifiers, Motion control • motor controls
