AutomationDirect’s C-more EA9 series of touch screen HMIs now includes a 10-inch widescreen model and a 15-inch base model touch panel.
The new C-more 10-inch full featured EA9-T10WCL widescreen color TFT touch panel ($685) has three serial ports, an Ethernet 10/100BaseT port, two USB 2.0 ports, one slot for SD memory card and audio line out. Widescreen resolution is 1024 x 600 pixel WSVGA in 64k colors.
The C-more 15-inch base model EA9-T15CL-R color TFT touch panel is $1299.00 and includes one Ethernet 10/100BaseT port, one serial port, two USB ports and two SD memory card slots. Screen resolution is 1024 x 768 pixel XGA in 64k colors.
Both touch panels are 12-24 VDC powered and an optional attachable AC power adapter is available. The panels are NEMA 4/4X and IP65 rated (for indoor use only) and are programmed using the EA9-PGMSW programming software, priced at $99.
C-more HMI touch panels have UL, cUL & CE agency approvals and are backed by a 2-year warranty.
