By David Herres
Thomas Edison, in the waning years of the 19th century, attempted to make a case for his preferred dc electrical system. But George Westinghouse and Nikola Tesla prevailed. AC has endured and with good reason. A simple passive device, the transformer, suffices to change voltage levels for transmission over various distances, and there is less corrosion at terminations because the electrochemical activity is self-cancelling as polarity reverses.The process of converting ac to dc, including filtering and regulation, is known as rectification. A simple, inexpensive rectifier can be built by placing a diode in series with an ac input. The diode conducts when forward biased and does not conduct when reverse biased. So the output of this half-wave rectifier consists only of the portion of the waveform either above the X axis or below it, depending upon how the diode is polarized.
The half-wave rectifier does not make good use of power available at the input. Moreover, this topology places heavy burdens on the diode and filter capacitors.
A full-wave rectifier, in contrast, makes use of the total input waveform. It converts both polarities to a pulsating waveform that can subsequently be filtered to create a high-quality dc. A center-tapped transformer with two diodes suffices to rectify both halves of the ac input waveform. Another circuit configuration that yields the same full-wave output consists of four diodes connected as a “bridge.” This bridge rectifier does not require the transformer to have a center tap, and the power flow is evenly distributed, boosting reliability and reducing maintenance.
In industrial applications, three-phase half-wave and full-wave rectifiers are used, the half-wave rectifier having three diodes and the full-wave rectifier having six diodes.
Many people, including experienced mechanics, are surprised to learn that an automotive alternator is actually three-phase. Six internal diodes provide bridge rectification so the output is dc with reduced ripple, ready for easily accomplished filtering to supply the audio system and other ubiquitous electronics.
The post Basics of rectification appeared first on Test & Measurement Tips.
Filed Under: Capacitors, Test & Measurement Tips
