Miles Budimir interviews Scott Orlosky, Engineering Manager at BEI Industrial Encoders about their new LT25 Linear Cable Transducer product.
BEI Industrial Encoders’ new linear cable transducer provides digital position and speed feedback information in a rugged, easy-to-install package. Model LT25 cable transducer utilizes a flexible measuring cable mounted to an internal spring-loaded spool and quadrature encoder output to precisely measure linear motion applications. The sturdy cable is made of nylon coated stainless steel for ultimate strength and has a measurement range up to 125 inches.
With an IP66 rating, the LT25 is a perfect solution for a variety of industrial measurement challenges including wet, dirty, or outdoor environments or applications where your measuring range travels over a harsh environment.
Cable transducers are also referred to as cable extension transducers, string encoders, or string potentiometers.
More product information can be found here BEI LT25
Filed Under: PODCASTS
