BellowsTech, LLC has released its new online edge welded bellows design form. Edge welded bellows design can be rather complex with the number of variables involved. The design form is intended to increase the knowledge of the customer by explaining each variable and giving the user the opportunity to complete the information.
The most critical factors in edge welded bellows design include the outside diameter, inside diameter, spring rate, pressure range and temperature range. With these factors, BellowsTech can begin the design of a bellows and work with the customer through the design process. The form provides definitions to each field to help the user understand why each variable is critical. For example, if the customer has a particular metal for their assembly, there is a field to complete it. If there is no material selected, BellowsTech requests the media, pressure and temperature information in order to find the most suitable material.
The design form is available in two forms: HTML webpage as well as a downloadable interactive PDF file. For customers looking to submit one design concept, the online version is suitable. There are no required fields, since some variables might still be undetermined. The online form has the ability to upload and attach drawings as well. The interactive PDF file allows the user to download the form, print, and save the information. If there are multiple designs or concepts, the PDF form will allow the user to keep track of the information. Once saved, the form can be emailed to the general sales email address [email protected] with a response within 24 hours.
To complete the online BellowTech, LLC Edge Welded Bellows Design Form, visit: http://www.bellowstech.com/contact-us/bellows-design-data-form/
BellowsTech, LLC
www.bellowstech.com
Filed Under: Bellows, MECHANICAL POWER TRANSMISSION, Mechatronics
