The new brochure provides an overview of Boston Gear’s open gearing design and engineering capabilities. A wide array of gearing solutions are available including spur gears, worm and worm gears, spiral and straight miter gears, bevel gears, and helical gears.
Engineering assistance is provided to help ensure that customers select the optimum gearing solution from over 2500 in stock gearing products, all with immediate availability.
If a stock gear is close to meeting customer requirements, Boston Gear engineers can quickly provide a stock product with various modifications including reduced face width, added keyways, added tapped holes, enlarged bores and reduced hub diameter and projection. Most modified stock gears are shipped within 24 hours.
In many cases, a fully customized gear solution is required. Customers can rely on the vast experience and expertise of Boston Gear engineers to design the most economical custom gearing solution without long lead times. Boston’s in-house test lab can simulate, evaluate and troubleshoot applications.
Boston Gear
www.bostongear.com
