Minijammer® brushless DC blowers deliver high performance in a compact package for low-voltage medical, combustion, and commercial end-uses requiring reliable and long life. Typical applications include medical devices (airbeds, laser therapy cooling, and lab equipment), gas-fired combustion systems (fryers and steamers), high-volume copiers, high-end digital printers, and fuel cells, among others.
All Minijammer blowers feature compact design with diameters of 5.0″ (127mm) and an overall total length of 3.0″. Their brushless DC motor technology promotes virtually maintenance-free operation over a long service lifetime.
The 12/24VDC blowers are available as standard flow or high flow systems. Depending on model, standard flow types can provide output pressure up to 13.5 in. H2O and flow rates up to 35.3 CFM and high flow versions can achieve output pressure up to 24.9 in. in H2O and flows up to 44.6 CFM.
Blower speed can be controlled using PWM, analog voltage signal, or onboard potentiometer. External speed control can be realized by incorporating a separate blower controller allowing for required 3 phase electronic commutated input. Internal or external drive electronics can be specified and full-wave drives can be integrated.
Minijammer blowers can be customized to meet particular application demands.
www.ametektechnicalproducts.com
:: Design World ::
Filed Under: Appliance engineering + home automation, Bellows, Medical-device manufacture
