The NEW valveless Fluid Transfer Pump from Fluid Metering, Inc. (FMI) delivers precision fluid control for process instrumentation.
FMI’s Valveless, Fluid Transfer Pump integrates CeramPump® pumping technology with the long life performance of a brushless DC motor and integral driver electronics. All that is needed is a simple 24VDC input power supply making FMI’s Fluid Transfer Pump an easy drop-in for existing instrumentation designs.
FMI’s unique CeramPump® valveless piston fluid control technology utilizes one moving part, a rotating and reciprocating ceramic piston to accomplish all fluid control functions within the pump, thereby eliminating the need for check valves typical of reciprocating pump designs. Sapphire-hard, dimensionally stable ceramic internal components substantially outperform peristatic pumps, whose accuracy is dependent on the memory and integrity of flexible tubing.
Fluid Metering Inc.
Filed Under: Pumps, Motors • dc
