Greenville, DE – Servo2Go has just added new CANopen models to its broad range of Programmable Stepper Motor Drive Systems from Applied Motion Products.
The STAC6 Step Motor Drive has proven itself in demanding applications, such as packaging and labeling machines, delivering up to up to 1400 oz-in with AMPs compatible range of low-loss, high performance step motors.
STAC6 drives are rated at 6A for the 110V version and 3.2A with the 220VAC version.
Adding CANopen allows the drives to be controlled by a CANopen master utilizing the DS301 and DSP402 communications protocols and the CAN 2.0b Passive physical layer. STAC6 drives have 7 digital inputs, 3 digital outputs and 2 analog inputs, encoder feedback is standard.
All AMPs CANopen compatible drives include Q programmer, Applied Motions powerful motion control language. Q programs can be downloaded and stored on the drive and then using the CANopen network, users can access, modify and trigger Q programs.
Servo2Go
www.servo2go.com
Filed Under: Drives (stepper) + amplifiers, Motion control • motor controls
