Cat 5e Cables from Alpha Wire
Alpha Wire has added Industrial Ethernet to its growing family of Xtra-Guard high-performance cables. The Cat 5e cables combine the advanced technology of Ethernet communication with the durability and temperature range of Alpha’s renowned Xtra-Guard 4 jacket, making it a perfect solution for demanding applications.
“The idea to use our Xtra-Guard 4 jacket on an Industrial Ethernet cable came from customers who needed a flexible and routable Ethernet cable that could withstand extreme environments,” said Tim Howlett, Senior Product Manager for Alpha Wire. “We decided to take it a notch further by offering 0 minimums on this line with put-ups as small as 100 feet.”
Cat 5e Cables
The Industrial Ethernet cables are available in a choice of unshielded, foil shield, or Supra-Shield® foil/braid. Alpha Wire’s Supra-Shield uses a combination aluminum/polyester/aluminum foil and tinned copper braid that offers exceptional EMI performance and flexibility. Additionally, the cables are UV and fluid resistant, meet UL 1666 Riser and CSA FT-4 flame tests, and are suitable for use in NFPA 79 applications.
This connectivity cable is available in a temperature range of -50°C up to +125°C on FEP-insulated constructions and -50°C up to +105°C on Polyethylene-insulated constructions. The TPE jacket is available in black with standard lengths of 100, 1000, and 2000 feet. Other colors, including red and teal, are available as special orders.
Alpha Wire
www.alphawire.com
Speak Your Mind
