Continuing to strengthen CC-Link’s position as a leading global open automation network technology, the CC-Link Partner Association (CLPA) announced today that ASCO has received CC-Link IE Field Network Certification for their Numatics valve manifold with G3 Fieldbus Electronics.
ASCO introduces its CC-Link IE Field certified Numatics valve manifold with G3 Fieldbus Electronics with integrated scalable I/O that is designed to work as a complete pneumatic valve manifold and I/O solution interfacing with CC-Link IE Field Industrial Ethernet Network applications:
• Numatics G3 CC-Link IE Field Communications Module (P/N: 240-362)
CC-Link is a high-speed, high-performance family of open automation network technologies that enable devices from numerous manufacturers to communicate, resulting in a fast, deterministic control system. CC-Link is managed by the CLPA, an organization comprised of manufacturers and users of CC-Link technology, academics and other interested parties.
ASCO is a global innovation leader in fluid automation technology. The ASCO product line has a history of technological breakthroughs. ASCO offers a broad range of 2, 3, and 4-way air-piloted and solenoid-operated directional control valves with fieldbus and I/O capabilities, along with a full offering of fluid power and fluid control products.
As a part of their fluid power line up, ASCO offers ISO & NFPA cylinders, ISO compliant valves, line-mounted valves, poppet valves for compressed air or vacuum service, lock-out and shutoff valves that prevent unauthorized pressurization, and valves designed for specific industries, such as SAE-compliant automotive valves. For applications that require rapid response and tight control over pressure and flow, ASCO has the automation industry’s most complete line of proportional valves!
CC-Link IE Field is a 1 Gbit/s Ethernet-based network that provides exceptional data bandwidth and transaction rates. It unifies the best of present technologies with an easy construction and a flexible network topology. ASCO is a proud member of CC-Link Partner Association (CLPA). You can learn more about ASCO.com.
About the CC-Link Partner Association (CLPA)
Established in 2000, the CC-Link Partner Association (CLPA) is an international organization with more than 2,600 member companies worldwide.
TEL: (847) 478-2647
E-Mail [email protected]
CCLinkAmerica.org
