The CeeLok FAS-T connector from TE Connectivity (TE), Harrisburg, Pa., is now available in square flange receptacle shell versions for both wire-applied and printed circuit board-applied applications.
This connector easily meets 10 Gigabit Ethernet speeds, with ample headroom for even the most stringent link budgets. The connector achieves strong signal integrity due to the patented T-shaped pin pattern that provides noise cancellation and decoupling to minimize cross-talk. The CeeLok FAS-T connectors have been designed for optimum performance in some of the harshest environments in military, commercial aerospace and marine/offshore applications.
“The square flange receptacle measures just 0.913 in. on each side and provides an outstanding choice for customers seeking high-speed signal transmission in environments where high vibrations may preclude the use of a jam nut style shell,” said Earle Olson, Business Development Manager, Global Aerospace, Defense & Marine, TE Connectivity. “This new small form factor, rugged, field terminable I/O connector enables a wide cross-section of industry uses from in-flight applications for commercial and military platforms, to meeting ground-based and marine-based needs.”
The CeeLok FAS-T connector provides an easy to terminate, high-speed/bandwidth interface that in a smaller and lighter weight design.
This new receptacle shell configuration is available in electroless nickel or low reflectivity black zinc nickel plating. Additionally, TE now offers a range of lanyard-attached, sealed, EMI-resistant protective caps for use with both plug and receptacle CeeLok FAS-T connectors. The protective caps have been designed to pass IP67 and, like the connectors, are available with electroless nickel or low-reflectivity black zinc nickel plating.
The CeeLok FAS-T connector easily meets today’s high-speed signal requirements for both cat 5e and cat 6a cabling and is a true 100-Ohm impedance connector compatible with various other high-speed protocols. It features crimp-snap contacts that enable easy termination and field repairability. Its unique integral backshell provides 360-degree shielding and drives down weight and cost, while significantly improving overall system performance.
TE Connectivity
www.te.com
The post Connector features square flange receptacle shell appeared first on Connector Tips.
Filed Under: Connectors (electrical) • crimp technologies, Connector Tips
