Working with high-pressure hydraulics is associated with a danger to your life. Therefore, it is vital to eliminate risk as far as possible. When using high-pressure products from CEJN, you can rest assured that you have made a safe choice, as we work on safety throughout the entire production chain using our knowledge gained from 40 years of experience.
CEJN is now releasing a new technology for your safety: CEJN INFORMATION SYSTEM (CiS) – a tracking solution in which every hose kit is chipped and has individual marking and traceability based on Near Field Communication (NFC*). This means that you can not only check technical data, but can also view an update history log: when the hose was first and most recently pressure-tested and when it is time to take it out of service.
CEJN CiS – How does it work
CEJN CiS is delivered on demand. To check hose kit status, install software and/or download app. Place tag over either USB-driver, make sure software is started, or place tag over phone with app started. When chip has been scanned all available data of the particular hose kit will be display. Note – this technology cannot detect damages or other injuries on hose kit.
CiS – Mobile Interface • Off-line • NFC* enabled phones (Android) • Read function • Quick on-site safety check |
CiS – Computer Interface • USB Reader type: ARC 122 • Windows 7, 8 or 10 compatible • Read and Write function • Update the hose kit history logg • Export all tags to database (Excel) |
1. Text field with history 2. Coupling part nr 3. Unique ID 4. Working Pressure 5. Pressure tested by… 6. Recommended date for re-testing
CEJN
www.cejn.com
Filed Under: Hydraulic equipment + components
