The CPA100 Capacitive Sensor from Lion Precision has a setpoint (switched) output to indicate presence/absence like a typical proximity switch, but the nonlinear analog output is capable of resolutions as low as 15 nm RMS (150 nm p-p). The new sensor features a unique front panel range indicator to alert the operator to out-of-range conditions, DIN rail mount electronics, and user adjustments for Offset (Zero) and Gain. A selection of probes provides standard measurement ranges from 0.05 to 6 mm. Offset and Gain can also be controlled with remote potentiometers if the device is enclosed in a control panel. Sync connectors allow interference-free use of multiple sensors with the same target.
Typical applications for the CPA100, besides basic position monitoring, include production line part sorting; double sheet detection in printers or related processes; and monitoring of processes involving nonconductive materials such as films, fabrics, and applied coatings such as adhesives.
CPA100 Specifications:
–Resolution: 0.03%F.S. RMS @ mid-range @15 kHz (typical)
–Bandwidth: 15 kHz (-3dB)
–Maximum Temp. Drift: Electronics: 0.2% F.S./°C; Probe: 0.05% F.S./°C
–Analog Output: 0-10 VDC
–Setpoint Output: Solid state switch closure; 30 VAC/60 VDC max
–Operating Temperature: 40°F-120°F; 4°C-50°C
–Input Power: 15-24 VDC, 2.5 W
Lion Precision
www.lionprecision.com/cpa100
Filed Under: Sensors (proximity), SENSORS, TEST & MEASUREMENT
