WOOD DALE, IL – Danaher Motion introduces CT Series Step Motors. The CT Series uses less power to provide more torque than comparable standard hybrid step motors. This improves operating efficiency and increases machine throughput, while reducing machine size and operating costs. Standard and custom motors are available in NEMA 17, 23, and 34 frame sizes.
“The CT Series has a patent-pending aluminum housing that improves heat dissipation and provides higher torque output. It uses less power than competitive step motor systems to achieve the same torque output, or equivalent power to achieve 25% higher torque output and greater machine throughput. The CT Series is ideally suited for use in higher capacity machines, or in smaller machines that require a compact, powerful motor, as is often desired in medical equipment, textile, semiconductor and electronic assembly applications,” says Rich Lenzing, Product Manager.
CT Series step motors also have a large bearing system to accommodate high thrust loads and high side loading. The load mounts directly to the motor shaft. This reduces mechanical system costs by eliminating couplings and load support bearings. High voltage insulation further increases reliability. The motors can be used with high voltage, high performance drives.
Danaher Motion
1500 Mittel Boulevard
Wood Dale, IL 60191-1073
Tel: 1-866-993-2624
Fax: 1-636-281-1517
E-mail: [email protected]
Web: www.DanaherMotion.com
About Danaher
Danaher Motion is a leading global manufacturer of motion control products that improve the efficiency and productivity of complex manufacturing operations. Danaher Motion’s product innovations have been revolutionizing the motion control industry for over 60 years through trusted brand names including Dover, Kollmorgen and Thomson. Danaher Motion is a strategic business platform of the Danaher Corporation (NYSE: DHR), a manufacturer of process and environmental controls, tools and industrial components.
:: Design World ::
Filed Under: Appliance engineering + home automation, Semiconductor manufacture, Medical-device manufacture, MECHANICAL POWER TRANSMISSION, Mechatronics, Motors • servo
