Sutton, MA – Specialty Products, Inc. introduces custom fabricated O-rings made from specialty materials for use in a wide range of pumps, valves, compressors, and devices used in medical instruments and other critical sealing applications.
Interstate’s Specialty O-Rings can be made from perfluoroelastomer (PTFE), Viton®, neoprene, nitrile, EPDM, solid and cellular urethane or silicone, and santoprene. Designed to match specific application requirements, they can be spliced, vulcanized, and supplied in sizes from 1/32” to 48” I.D. with 1/16” to 1/4” cross sections, depending upon material and construction.
Material selection for Interstate’s Specialty O-Rings depends upon customer requirements with regard to fluid compatibility, temperature and different- tial pressure-, abrasion- and tear resistance, configuration, service conditions, installation considerations, and other factors. They are available in hardness from supersoft to 90 Durometer.
Interstate Specialty Products, Inc.
www.interstatesp.com
Filed Under: Seals • O rings, FLUID POWER, Materials • advanced, Seals
