Network television may seem like an unlikely source for manufacturing innovation, but don’t say that to the designers of the robots competing in season two of ABC’s BattleBots (a 10-episode run started Thursday, June 23).
Two competitors in the show turned to Proto Labs for prototyping and end-use parts for their warrior robots’ “devious designs,” as a program promo described them.
Design challenge #1: enter the Ringmaster
Hal Rucker, a San Carlos, Calif. freelance product designer and BattleBots contestant, initially discovered Proto Labs several years ago after searching online to find quick-turn manufacturing vendors.
“In the last several years, after using several vendors, Proto Labs is the one I go to most often,” Rucker says. Why? In a word — speed.
In fact, turnaround time was the biggest design challenge Rucker faced for his TV BattleBot, which he named The Ringmaster because its weapon is a ring that circles the robot. He started building his robot at the end of January, and needed to complete it in time for the television show’s competition, which was taped April 15 through 25.
“The biggest deal for me was getting these parts done so quickly because I only had three months to design and build and test this complex machine,” Rucker says. Throughout the design and build process, he ordered parts several times from Proto Labs and received shipments within three days of ordering.
A suite of services — and solutions
Beyond speed, Rucker knew he wanted to use 3D printing for plastic prototypes and production parts, and CNC machining for magnesium end-use parts, and he knew Proto Labs offered those services and materials.
Rucker ended up being the only competitor on the show who fabricated most of the parts for his BattleBot out of magnesium. He chose magnesium because of a weight restriction rule, limiting the BattleBots to 250 lb or less. “So I wanted to make it as strong as possible but as light as possible,” Rucker says. Magnesium has emerged in automotive, aerospace and other industries as a frequently preferred alternative to steel and aluminum because of its strength and lighter weight.
Proto Labs also manufactured additional end-use parts for Rucker’s BattleBot. These parts included four 3D-printed (stereolithography) holders made of a durable ABS-like thermoplastic for its LED power indicators, several CNC-milled parts that came together as an industrial-grade chassis for the weapon-motor assembly for the BattleBot, and a machined face plate for the motor that is in the BattleBot’s drive system, which powers and moves the BattleBot.
Before actual production parts were manufactured, Rucker used Proto Labs to produce two different prototype pulleys for the BattleBot’s eventual weapon, which were CNC turned on a high-speed lathe. Rucker made the final pulleys himself.
“The finished robot worked well and performed exactly as we had hoped and first drew it up,” says Rucker. “Everything, including the parts we got from Proto Labs, lived up to expectations.”
Design challenge #2: shifting into overdrive
The second competitor in the ring who worked with Proto Labs was Christian Carlberg. As an independent product developer and designer, Carlberg says, “It’s my business to quickly develop ideas for people.” As a result of that work, the San Luis Obispo, Calif.-based designer says, “Proto Labs has been on my radar for a long time,” and he has used the company’s rapid manufacturing services for contracts he has done for a variety of companies.
When Carlberg and his 13-year-old daughter Carissa, working under the name C2 Robotics, began crafting their battle bot named Overdrive for the show, Carlberg chose Proto Labs as his manufacturing supplier.
For Carlberg, Proto Labs’ design for manufacturability (DFM) analysis was an especially key tool for this project. “My design philosophy is to have one complicated part and then keep all subsequent parts as simple as possible. I turned to Proto Labs to make that complicated part. But I also found Proto Labs’ online quotation system valuable. It allowed me to evaluate and simplify my parts.”
For the Overdrive robot, Carlberg used Proto Labs’ CNC machining service to fabricate two sets of parts for the weapon-pulley system. Two sets were produced because Carlberg created two robots, a hero — the primary robot — and a back-up bot.
Proto Labs milled the parts: shaping the parts, putting in the bearing bore, the outside shape, and the custom spline shape for a weapon bar. Following that process, Carlberg did the turning himself, for belt-transmission grooves for the pulley system. All parts made by Proto Labs were end-use parts.
Overdrive’s outcome
“All of Proto Labs’ stuff worked well and nothing broke,” says Carlberg. He was also pleased with Proto Labs’ quick-turn capabilities. “Normally, it would take you two months to have something machined and then heat treated; we were able to compress it to three weeks.”
This speed, Carlberg says, was especially important, given the tight deadlines involved in a television production. “The show was not going to wait for me to finish the robot. Sometimes, on a regular project, you can slip a couple of days, but you can’t miss a deadline on a TV show, it won’t get filmed.”
Happily, Carlberg says, though there were plenty of other teams that were “working last minute” on their robots, “We were one of the few teams that walked in with not one but two ready robots, hero and back-up, and I have Proto Labs to thank for that.”
Proto Labs
protolabs.com
Filed Under: Rapid prototyping, Make Parts Fast, PODCASTS
