Muncie Power Products offers a family of directional control valves built with higher pressure capabilities to withstand the most extreme applications.
Featuring high-grade iron castings and nickel-plated or hard chrome spools to meet high pressure applications, the family includes three series. Different spool, control, positioner and accessory options allow for customization of the V080, V130 and V250 Series.
The V080 is designed for a maximum flow capacity of 30 gpm and a max pressure of 5075 psi. With a maximum flow capacity of 55 gpm and a max pressure of 5440 psi, the V130 is a mid-size option. Muncie Power Products latest directional control, the V250, allows for higher flow rates. It is designed for a maximum flow capacity of 75 gpm and a max pressure of 4000 psi.
Each work section is pre-assembled and 100% tested prior to shipment.
munciepower.com
Filed Under: Hydraulic equipment + components
