Donaldson Co. (NYSE:DCI) is expanding availability of the company’s state-of-the-art line of high-performance hydraulic cartridge filters to mobile equipment and engine aftermarket distributors by May 2011.
Donaldson high-performance hydraulic filter cartridges, designated as the DT line, provide 73% higher dirt-holding capacity and 47% lower initial pressure drop than traditional filters. Using Donaldson Synteq media technology, these filters allow higher initial cleanliness and provide superior system protection.
Donaldson high-performance hydraulic cartridges are a cost effective solution, reducing maintenance cost by extending filter life which, in turn, results in longer change intervals. This family of high performance hydraulic filters is ideally suited for a variety of demanding applications, including use in construction equipment, hydro-static drives, transmissions, bearing lube oil systems and other heavy-duty applications.
Donaldson Co.
www.donaldson.com
Filed Under: Hydraulic equipment + components, FLUID POWER, Off highway • construction • agriculture, Filters (electrical) EMI • COTS • noise filters • shielding
