Piab is introducing a complement to its range of Value Line vacuum ejectors. The new aluminum block mounted ejector is dimensioned to emulate a popular ejector format, making it easy to install into many existing systems. Offering improved performance and more energy-efficient operation, the ejector is a cost-effective and easy-to-install alternative for operators of basic automated vacuum systems.
Value Line is Piab’s economy range for less demanding industrial applications that do not warrant the use of Piab’s specialist vacuum solutions. So far, the range has included small, light-weight vacuum ejectors in two different designs – inline or T-design.
Piab’s vacuum ejection technology is based on ejector cartridges that offer improved vacuum performance compared with conventional single-stage ejectors of corresponding size. Hence, energy savings of up to 28% can be achieved if the company’s Value Line ejectors are used to replace similar ejectors. Designed without flap valves, the ejectors are reliable even in dirty and dusty environments.
Piab
www.piab.com
Filed Under: Pneumatic Tips
