Designed for rugged applications and those that require a light source with hazardous location ratings, NEW EF1A flood lights are well-suited to handle applications in oil & gas, water treatment, chemical plants, painting booths and more!
With UL Class I, Zone 1 approval and a 4X rating, the EF1A series can be used in harsh locations. Plus, compared to traditional lighting sources, these highly-efficient LED units have a much longer life, which means less operating expense and hassle! This design also allows for increased mounting versatility with mounting options including adjustable, fixed angle, or no mounting bracket.
Narrow or wide-angle beam models are available with a choice of clear or translucent lenses, and 24V DC or 100 to 240V AC voltage. EF1A is offered with a pushbutton on/off switch (Type 3S rating) or with a Type 4X rating without the switch.
EF1A flood lights are ideal for lighting industrial and hazardous location applications. For more information on the EF1A series of LED machine lighting, call 1-800-262-IDEC (4332).
IDEC
IDEC
Filed Under: Aerospace + defense, Factory automation, Lights • signal lamps • indicators, Flanges • supports • mounts • brackets, Off highway • construction • agriculture, Motors • ac
