EnvisionTEC recently released a new 3D printer—the Aria.
The Aria produces parts with excellent surface finish and function. Z layer resolution can be set at 25, 35 or 50 microns, depending on material.
Built on EnvisionTEC’s popular Micro platform, the Aria suits industrial parts, jewelry, and miniatures applications.
Machine highlights:
–simple user-friendly machine design
–powered by industrial-grade UV LED light engine
–easy-to-use software for preparing jobs
–transfer job files over Ethernet or USB
–touchscreen operation
–easy to swap materials with no waste
Technical specifications:
–build Area: 2.36 x 1.77 x 3.94 in. (65 x 40 x 100 mm)
–footprint: 9 x 9.5 x 24.2 in. (22.86 x 24.13 x 61.5 cm)
–electrical requirement: 110 VAC @ 3A
–weight: 35 lbs (16 kg)
EnvisionTEC
www.envisiontec.com
