EOS, a technology and market leader for design-driven and industrial additive manufacturing, expands its metal materials portfolio with EOS Titanium Ti64ELI and EOS StainlessSteel 316L.
EOS Titanium Ti64ELI: light metal alloy – corrosion resistant and biocompatible
Parts built in EOS Titanium Ti64 have a chemical composition and mechanical properties corresponding to ASTM F136. With high-detail resolution, this alloy can be processed on an EOSINT M 280 (400 Watt) metal laser-sintering system and shows an excellent corrosion resistance. Due to its biocompatibility and high grade of purity it is suitable for the additive manufacturing of medical implants.
EOS StainlessSteel 316L: corrosion resistant and biocompatible stainless steel
This stainless-steel alloy is for processing on the EOSINT M 280 metal laser-sintering system. It shows a good corrosion resistance and a high ductility. Parts built from it have a chemical composition corresponding to ASTM F138 (“Standard Specification for Wrought 18Cr-14Ni-2.5Mo Stainless Steel Bar and Wire for Surgical Implants UNS S31673”). In the medical industry, this alloy is suited for surgical instruments, endoscopic surgery, orthopedics and implants.
The material is also a good choice for use in the watch and jewelry industries, where the designer benefits from extensive freedom of design. Shaping and structural restrictions as such are a thing of the past. Parts such as watch cases (thanks to defined hollow spaces) can be manufactured more cost-efficiently and easily, saving resources. The material is also well suited for additive manufacturing applications such as spectacle frames or functional elements in yachts. In the aerospace industry, EOS StainlessSteel is a good choice for the manufacture of clamping elements or heat exchangers. Parts manufactured from that material can be mechanically post-processed or polished.
EOS
www.eos.info
Filed Under: 3D printing • additive • stereolithography, Make Parts Fast
