The DZE & DZS series of servo drives for EtherCAT enabled control networks fit in the palm of your hand. The ‘DxM’ – Demultiplexed Motion technology connects up to 3 DZS drives (sub-nodes) to a single DZE (node) on an EtherCAT® network for up to 4 axes of servo motion. ‘DxM’ technology handles all sub-node activity through one node, making master tasks much simpler in multi-axis systems.
The DPE series of EtherCAT enabled servo drives are part of the panel mount DigiFlex® Performance™ platform. Both DPE’s and DZE’s can be used as stand-alone EtherCAT® slave nodes in single-axis setups or as part of a larger, multiple axes EtherCAT network. The DZS’s must be used as sub-nodes in a ‘DxM’ configuration with a DZE node.
Advanced Motion Controls
www.electromate.com
Filed Under: CONNECTIVITY • fieldbuses • networks, Drives (servo) + amplifiers, Motion control • motor controls
