With the appropriate criteria identified and a little web searching, pressure sensors designed to survive in harsher environments can be found. Also, pressure sensors with evaluation kits are available from several companies. However, a pressure sensor evaluation kit for a harsh environment pressure sensor is rather unique. Merit Sensor’s’ MeriTREK evaluation kit is in this unique category. It allows users to quickly and easily test the performance of its TR Series pressure sensors. The kit comes standard with a 100 psia part (TR1-0100A-001) with standard face seal but gage and other TR units are available. The stainless steel housed sensor has a height of 4.57 cm and a diameter of 3.18 cm and comes with a Phoenix Contact electrical connector.
For more information about the MeriTREK evaluation kit, click here.
Filed Under: Sensors (pressure), Sensor Tips
