ROSS Controls introduces an expansion to its existing DM Valve Series for Air Dump/Release applications. The ROSS DM1 Series C Valve is a Control Reliable Double Valve with dynamic monitoring that can be used in Category 4 PL e applications that do not require dynamic memory. The DM1 Series C Valve is available in port sizes ranging from ½–1-in. and is base mounted for convenience.
The ROSS DM2 Series C Explosion Proof Valve is a Control Reliable Double Valve with dynamic monitoring and dynamic memory that can be used in Category 4 PL e applications in hazardous locations categorized as Ex m II T4 and Division 1.
Control Reliable Energy Isolation Valves enable rapid exhaust of downstream air when de-energized to remove stored energy and allow safe access to work areas. The DM1 Series C and DM2 C Series Valves are the latest additions to the ROSS’ Energy Isolation Valve family that covers a wide range of sizes and options including being combined with lockout valves and filter regulators in air entry packages.
ROSS Controls
www.rosscontrols.com
Filed Under: Valves, Pneumatic Tips
