The EZLogix automation controller is a low cost, advanced programmable logic controller (PLC) that is IIoT and Wifi Ready, has USB data logging up to 64 GB, unparalleled Free programming software and simulator package and much more. It is an American manufactured rugged modular rack din-rail mountable PLC with incredible features and prices with a CPU starting at $149.
The EZLogix controllers are ready for Industrial Internet of Things (IIoT) applications. With an integrated message queuing telemetry transport (MQTT) protocol, direct connectivity to external devices (such as sensors, analog inputs, etc.), and easy-to-setup secure communication with other networks (such as Modbus RTU & TCP/IP), the EZLogix is designed not only to be a PLC, but also a low-cost edge-gateway computer/controller. The EZLogix can also act as a “bridge” between existing operational technology within a plant, such as factory machines and plant database networks, so valuable data can be shared reliably and securely to improve plant productivity and efficiency.
The EZLogix Designer Pro Software includes simple ladder logic programming, advanced function blocks, an unparalleled simulator that allows you to test all logic without any hardware, automatic I/O configuration, auto-tuned PID control and much more.
AVG Automation
www.avg.net
Filed Under: Factory automation, IoT • IIoT • Internet of things • Industry 4.0, AUTOMATION, CONNECTIVITY • fieldbuses • networks, ENGINEERING SOFTWARE, ELECTRONICS • ELECTRICAL, PLCs + PACs
