Fastec Imaging’s TS5 handheld High-Speed Camera enables you to record any rotating machinery or equipment moving at high-speed and susceptible to vibration problems for performance analysis or troubleshooting using slow motion replay.
This handheld, portable, battery operated camera with a large built-in LCD touch screen and an intuitive on-screen menu system puts the power of both a traditional high-speed camera and long-record system into the palm of your hand. The TS5 is a true point-and-shoot high-speed camera solution with four models to choose from, boasting crisp, clean video from 2560 x 2080 @ 230fps to 800 x 600 @ 1650fps, there is an IL5 to fit your application needs.
All models record more than 3200 fps at VGA resolution and more than 18,000 fps at smaller resolutions. Saving images at ultra-fast speed to the onboard media while simultaneously recording high-speed bursts of hundreds or even thousands of images at a time, the TS5 is always ready for the next high-speed snapshot. With a base model starting below $13,000, the TS5 is a cost-effective solution to record high-speed events for slow motion analysis.
Built for flexibility and ease of use, the TS5 can be operated as a self-contained camera or controlled over Gigabit Ethernet via Fastec FasMotion software on your PC/Mac, or via the built-in web interface on your PC, Mac, tablet, or even your smartphone. The FasMotion application makes workflow a breeze with transfers of uncompressed images via Gigabit Ethernet at rates of 50–80MB/s to most PCs. The TS5 features both a USB port and an SD port for quick and easy image downloads to USB flash drives, SD cards, or portable hard drives. The built-in SSD provides up to 1TB of lightning-fast non-volatile internal storage.
The post Fastec Imaging’s TS5 high-speed camera appeared first on Robotic Tips.
Filed Under: Robotics • robotic grippers • end effectors, Vision • machine vision • cameras + lenses • frame grabbers • optical filters
