The xPico Wi-Fi SMT embedded device server is a certified, compact Wi-Fi surface mount module for quick and easy serial-to-Wi-Fi connectivity. The server extends the features and benefits of the existing xPico Wi-Fi module to a surface-mountable form factor. It helps users develop IoT applications and solutions, especially those requiring direct access to device data through smartphones, tablets and connected PCs.
xPico Wi-Fi features and benefits
- Simultaneous Soft-AP and Client Mode: Permits a service technician mode or direct local access without disconnecting from the enterprise wireless network
- Complete Wi-Fi Connectivity Offload: Reduces complexity of application microcontroller and helps bring products to market faster with less risk
- Complete Network Protocol Offload: Built-in Web Server, TCP/IP network stack, file system and network connection management can be used without writing complex application logic
- Over-the-Air (OTA) Updates: Enables reliable remote upgrades to xPico Wi-Fi firmware over the Internet, while preserving custom configurations
- Web Service API: Use popular Web methodologies to communicate with and manage the connected device from cloud applications, mobile devices and browsers
- Industrial Ready: Operating environment at extended temperatures: -40 to 85° C
- Secure: 256-bit AES encryption
- Low Power: Multiple power management modes for battery-powered operation
- Choice of Footprint: Connector or surface mount formats, with on-board antenna and u.fl connectivity available, based on application requirements
- Certified: Modular certification (FCC, IC, Japan, AU/NZ) and regulatory approvals for CE
SMT added features
- Surface Mount: Castellation footprint makes it easy to integrate with commonly available PCB assembly processes
- On-board Antenna Option: Completely integrated solution that does not require additional Wi-Fi specific components
- u.fl Antenna Option: Permits flexibility in placement of module and antenna within the product for optimal performance
- Small Form Factor: Measuring only 18.3 x 31.1 x 3, it can be fitted into small spaces with low height profiles
Lantronix Inc.
www.lantronix.com
Filed Under: Wireless • 5G and more, Wireless devices, MOTION CONTROL, MORE INDUSTRIES, ELECTRONICS • ELECTRICAL
