Standard flange, inlay flange, and dowel hole flange mounted supports accommodate 3 to 50 mm, 8 to 30 mm, and 12 to 30 mm shaft diameters, respectively. Additional offerings include each of these types with inlay slit clamp supports, as well as hinged clamp style supports, chamfered head design supports, and shaft supports with a built-in damper.
MISUMI USA, Inc.
www.misumiusa.com
Filed Under: Flanges • supports • mounts • brackets
