NB’s Slide Bushings come in an array of configurations, such as lightweight, standard, clearance adjustable, and open. NB bushings give smoother, more precise movement. Their wiper seals are the highest quality precision grade. NB’s round, square or two side cut Flange Slide Bush line has the mounting ease of a flange. Choose from single, double-wide, or center mount. Available in inch, Asian or European metric dimensions. Shaft diameters from 3.175 mm to 50.8 mm; 0.125 to 2 in.. Bushing lengths from 12.7 mm to 203.2 mm; .5 to 8 in.. Detailed drawings and tables provide dimensional and mechanical information. Now also available in 3-D CAD.
COMP: NB corporation of America / NIPPON BEARING Co.,Ltd.
:: Design World ::
Filed Under: Factory automation, Bushings • plain (sleeve) bearings, Machine tools + subtractive manufacturing, MECHANICAL POWER TRANSMISSION, Motion control • motor controls
