The Sensor Connection a division of Harold G. Schaevitz Industries LLC, has expanded its line of temperature sensors with the addition of the CHT-FS series Cylinder Head Temperature (CHT) Sensor. Installed under the spark plug or head bolt for monitoring of engine performance and critical over-temperature conditions. The unique flexible stem design allows for installation in high temperature areas with limited clearance.
Features:
• Type K Thermocouple
• Temperature Measuring Range: -40°C to +1000°C
• Available for 10, 12, 14, or 18 mm OD bolts/spark plugs
• Custom Flexible Stem lengths available
• Made in the USA
Typical Applications:
• Unmanned Aerial Vehicles (UAVs)
• Light Aircraft
• Power Generators
• Automotive Engine R&D
• Motorsports
Sensor Connection, Div. of Harold G. Schaevitz Industries LLC
thesensorconnection.com/cht-sensors/all-cht-sensors/type-k-cht-cylinder-head-temperature-sensor-flexible-stem-type
Filed Under: Sensor Tips, SENSORS
