Special greases or lubricants are needed if industrial equipment could incidentally contact food at any point in a food and beverage application. H1 grease is a food-grade lubricant used in food processing environments and as part of the Class H1 lubricants, is approved by the Food & Drug Administration (FDA) and may be used on equipment and machine parts that are used to manufacture food and drink for human consumption.
Brother Gearmotors supplies the H1 grease in its gearmotor products through its assembly facility in Bartlett, Tenn. At this facility, you will also find a range of gearmotors, including 16 different gear ratios and six voltage options, along with a range of bore sizes for the company’s gearmotors.
These gearmotors are light, reliable and compact in size; deliver high torque at low speed; are sealed for life for maximum efficiency and reduced labor; and have a high-quality, durable, e-coat paint to withstand the toughest environments.
Brother Gearmotors
brother-usa.com/gearmotors
Filed Under: MOTION CONTROL, MORE INDUSTRIES, Motors (gearmotors)
