The N-Tron series Gigabit 1000-POE+ Power over Ethernet Plus (PoE+) injectors deliver power and data over a single Ethernet cable to any PoE+ or PoE-enabled device, eliminating the need for additional power cables. These items let you add new technology without disrupting existing networks.
The 1000-POE+ is a plug-and-play, unmanaged injector that enhances the performance of industrial PoE devices. With a single industrial Gigabit Ethernet port for connectivity to any IEEE 802.3af/at-compliant hardware, the 1000-POE+ fits such applications as security cameras, panel displays and wireless access points in oil and gas, water/wastewater, utility, transportation, mining and factory environments. Providing up to 30 watts of output power and a wide operating temperature the injectors help conserve wiring space. Operating temperature range is 40° to 80° Celsius. LED status indicators let you know with a-glance power and connectivity status.
Red Lion Controls
www.redlion.net
Filed Under: Ethernet — cables • hubs • switches, MOTION CONTROL
