SCHURTER, a leading provider of fuse holders, expands its CSO heavy duty fuse clip family with a cost-effective tin-plated version. The CSO clip, designed for 10.3 mm diameter fuses, is suitable for applications with voltages up to 1500 VAC/VDC and currents to 32A. These unique characteristics are SCHURTER’s response to the increasing photovoltaic system voltage requirements.
The CSO clip is available in solder and screw/rivet versions. The solder version allows direct mounting on a printed circuit board by means of through-hole technology. The screw/rivet version provides additional flexibility for basic designs. Due to the special copper alloy all versions are characterized by a strong clamping force resulting in minimal power loss. The CSO fuse clip is ideal for a wide range of PV and other DC applications including inverters, battery charge controllers, and string fuse holders.
Furthermore, the CSO is well suited for applications in the industrial and mobile electronics sectors. The fuse clip conforms to RoHS specifications and is currently the only photovoltaic clip on the market with cURus approval. SCHURTER also offers the ASO 10.3×38 PV fuse to fit the new CSO fuse clip. In addition, the fuse clip supports other fuses with a 10.3 mm diameter of any length. This includes, for instance, 10.3×85 mm fuses for higher voltages.
SCHURTER
cso.schurter.com
Filed Under: Fuses, Power Electronic Tips
