WAGO Corporation’s Custom Products Division has shoehorned a 6A Solid State Relay and User-Configurable On/Off Delay Timer into a 6mm housing. Engineered for high cycle applications, 859 Series Solid State devices surpass the performance of 5mm/2A units while providing greater adaptability than 6A 11- and 22mm-wide units. Eliminating electromechanical elements, 859 Series avoids G-ratings common to heavy-duty packaging, injection molding, shipbuilding and non-automotive transport applications.
The DIN-rail Solid State Relay (859-941) and Timer (859-475/001-000) support space-restricted panels with heat dissipation of less than 1W. Both high efficiency devices feature an integrated fused output for overcurrent protection up to 6A. An on-unit LED indicates the Timer’s output switching status or Relay’s open/closed output status. CAGE CLAMP® COMPACT Spring Pressure provides vibration-proof and maintenance-free terminations for conductors 28–14 AWG.
Solid State Relay:
DIP-switch equipped 859-941 Relay provides input voltage ranges of 5–10V, 10–24V and 24–30V and operating temperature range of 0–40°C. Maximum switch frequencies (50% duty cycle): 200Hz (6A), 300Hz (5A) and 400Hz (4A). Output is 19.2–28.8VDC.
Solid State Timer:
The 859 Series Solid State Timer carries an on-unit DIP switch, as well as top-mounted adjustable potentiometer — fine tune without removing from DIN-rail. Timer range: 0.25–2 seconds, 1–8 seconds, 5–75 seconds or 35 seconds–10 minutes. Standard operating temperature range is 0–40°C; alternate range is 0–70°C at 5A max (24VDC).
WAGO Corporation
www.wago.us
Filed Under: Relays, ELECTRONICS • ELECTRICAL
