With the addition of UL Type 4X and Type 13 approvals, IDEC high-performance 5.7” HG2G HMIs now provide a degree of protection against corrosion, dust, spraying water, oil, non-corrosive coolant, and damage from external ice formation. Suitable for applications in harsher conditions, especially where protection against corrosion is required, such as in oil and gas, food processing, marine, waste water treatment plants, bottling plants, and pharmaceuticals, the possibilities are endless!
A super bright LCD screen (800cd/m²) with 65K colors provides crisp, vivid images and superior visibility, even in intense light or at an angle. These high-performance HMIs also allow you to remotely monitor and control your application from a PC, tablet or smart phone. This is an efficient way to troubleshoot, test and do maintenance regardless of your location.
High-performance HG2G HMIs support an SD memory card and USB flash drive, giving you extra room to store and transfer project data, logging data, images, video files and much more. Serial and Ethernet ports are included, allowing communications with PLCs using our supported Serial or Network Driver in 1:1 or 1:N Communications. Supported drivers include IDEC, Allen Bradley, Siemens, Emerson ROC, Modbus RTU, TCP/IP and many more. Plus, you can save space and cost by adding a MicroSmart expansion I/O card on the back of the HMI. All this and more can be programmed with our user-friendly and intuitive software, WindOINV2, with free upgrades.
All 5.7” HG2G High-performance models are Class 1 Div. 2 rated for hazardous locations, as well as being ABS, LR and NK approved, CE-marked, c-UL-us listed and IP66 rated. Our 5.7” HG2G Basic models (available in 256-color or monochrome) also offer Type 4X and Type 13 approvals.
For complete specifications and information on HG2G HMIs, call 1-800-262-IDEC (4332) or visit us online at www.IDEC.com/OIT.
IDEC
us.idec.com
Filed Under: Factory automation, Machine tools + subtractive manufacturing, Displays • HMIs • operator interfaces • monitors, Material handling • converting, Off highway • construction • agriculture
